Although the code stage offers great ability to extend Blue Prism, the development experience is not good.   It would great to have some level of formal integration with Visual Studio, or other applicable IDEs, for a better development flow.
Clicking on the the code tab in BP would launch Visual Studio and saving would bring code and libraries into BP.  Ability to fully test code in the IDE, even while debugging a VBO. stepping into a code stage would launch VS into active debug mode and then back out.  More transparency and visibility into missing libraries, global code issues, code validation errors would be great.
