Brian_Hesse
Status: Not Planned
TA Portal Quality screen needs better formatting. Error Code Selections should be a list box or Check boxes with multiple columns. Also allowing for descriptions to be added to Errors to display so users can intuitively select the appropriate codes not leverage an outside reference. Here’s an example of how bad it looks because we have screen-field level error codes
1 Comment
Status changed to: Not Planned
ustevens
