KristianRisager
Status: Delivered
​BP currently lacks the ability to edit expressions in the Evaluate Expression wizard. ​This leads to clicking back and forth a lot, and it is time consuming when testing different variable values.
Can you make it possible to edit expressions and evaluate them in the same window?
3 Comments
MelanieGiuliani
Community Team (Retired)
Hi Kristian,
Thanks so much for submitting your idea! We are moving it into the
 Under Consideration status while we route the idea through our internal review process.
Thank you!
Melanie
MelanieGiuliani
Hi Kristian,
Thank you for your idea! We've routed your idea through our internal review process, and have decided to move your idea to the Planned stage.
We will update you here once your idea has been delivered in the product.
Thank you,
Melanie
Hi @Kristian Risager Larsen,
I'm happy to confirm that this enhancement was delivered as part of the release of Blue Prism 6.10.0 - as a result I'm updating this idea to "Delivered".
Release notes for this version can be found here, and details of the enhancement described by your idea can be​ found under reference BP-1410.
Rob
