Martynas
Level 7
A way to disable scheduler without killing all current sessions. E.g. Sending a command to BP server:
"Finish all running executions and do NOT fire new schedules in next 6 hours"
It would allow to perform server maintenance, without breaking Blue Prism platform (given company has 2+ application servers running).
2 Comments
RobynSinglehurs
Would be good to be able to stop all schedules from running so that if you want to halt the system (upgrade, urgent service window) you can stop all schedules from running rather than having to go through them all one by one stopping them.  Allow them to end gracefully and then be able to restart them all rather than having to start them individually as well.
MelanieGiuliani
Community Team Alumni
Hi Martynas,
Thank you!
Melanie
