Automated Workflow-to-Process Conversion – We literally have several thousand workflows that have been built over time. It will take forever to go through business process modernization initiatives to rewrite or replace these, and therefore it will take a long time until these business processes can benefit from the AWD Process automation capabilities. Sure there are Interop Services, but it will become unwieldy to manage full automation through this capability. What I would like to see is a tool that works something like this:
1. Select a BA/WT
2. Automatically reverse engineer all the status routing steps and UIs
3. Select a target BA/WT
4. Auto draw a process that depicts the original workflow (yes, I know there are hurdles and things to deal with here, but I have some suggestions)
5. Allow the admin to deploy the new process
a. Optional – Inherit Permissions form the original workflow
b. Replace BA/WT/STAT fields and Update button with Next Step
