CKOMORO
- Mark as Read
- Printer Friendly Page
13-08-21
01:56 PM
Status:
New
Hi
at the moment anything you do in BluePrism you are connected direkt via AppServer to the Database. So you always have a kind of live connection for everything you do. That makes BluePrism kind of slow in Studio.
It would be great in Studio to have the option with database and without database. If the developer is done it just needs a button like publish to database and everything is okay.
During development he should have the option as well to save under C:\Temp for example. Later with the publish function process is saved in database.
Be aware iam just talking about Development Enviorment.
See more ideas labeled with:
