- Mark as Read
- Printer Friendly Page
Time to time VM resources and servers needs time for maintenance breaks. This can happen in scheduled (like once a month) or ad-hoc manner.
It would be time-saving feature that you can schedule a maintenance breaks by resource / by pool.
Why?
- Currently every schedule needs to be expired manually and they need to put back when the maintenance break is over.
- Normally these SQL server/ App-server maintenance breaks happens in night-time and they last from 1h up to 4h.
- At environments, where are dozens or hundreds of schedules, this is taunting task to do on monthly basis.
- By marking "maintenance break" for certain time slot -> Schedules do not try to start on that time interval. It will save manual work + night time runs will start after the marked maintenance breaks time slot is passed.
- Process controller does not need to remember put the schedules back on next day.
