MikkoRahikainen
Status: New
Time to time VM resources and servers needs time for maintenance breaks. This can happen in scheduled (like once a month) or ad-hoc manner.
It would be time-saving feature that you can schedule a maintenance breaks by resource / by pool.
Why?
- Currently every schedule needs to be expired manually and they need to put back when the maintenance break is over.
- Normally these SQL server/ App-server maintenance breaks happens in night-time and they last from 1h up to 4h.
- At environments, where are dozens or hundreds of schedules, this is taunting task to do on monthly basis.
- By marking "maintenance break" for certain time slot -> Schedules do not try to start on that time interval. It will save manual work + night time runs will start after the marked maintenance breaks time slot is passed.
- Process controller does not need to remember put the schedules back on next day.
3 Comments
ChristianPanhan
Great Idea.
In Addition: How about having an option to define maintenance windows and assign one ore more of those to a schedule?
For Example having two schedules:
Schedule 1: Uses Application A
Schedule 2: Uses Applications A, B, C
If we now set a maintenance for B only those schedule will not try to start.
Same could be done for the machines, the resource pc is running on.
MikkoRahikainen
Great addition Christian!
In Blue Prism terms, this can be seen as object related. So that if certain target application has an maintenance break -> Mark objects / object folders as under maintenance and all scheduled processes which are using those objects will not try to start.
MikkoKamppila
Agree 100%. Meanwhile, you could add an extra step to your processes that checks periodically if a certain maintenance related environment variable is set to true.
Or, you could have a bit more complex syntax like:
DB;16.7.2021;21;23
Naturally, you can have multiple rows to cover various maintenance windows.
In a process, split the variable text and check
a) if today is the maintenance day for a DB and if,
b) is the process' current "exit" time set between 21-23.
If yes, then let the process set the exit to happen before 21. Or, if it's necessary to continue after the maintenance is over, just let the process sleep/wait until the maintenance end hour is reached.
Similar approach can be used to delay/avoid the unwanted launch of apps while the maintenance is ongoing.
Unfortunately while the process runs, it won't check the updated environment variables. But for the scheduled ones, it's ok.
