Currently when items are loaded to work queue, the Created and Last Updated column in queue content is being populated by datetime.
When any of the items have been marked as exception and retried, datetime in Created column remains unchanged and when the same item gets completed, the Last Updated column is updated and the difference between these two columns does not match the Total Work Time column.
Would like to have new datetime in the Created column when item is retried so that when it gets completed, the Last Update column will be updated and there will be no difference in both columns when it comes to match the Total Work time column.
OR
Can have an one column which will be populating the retried items date item.
