Blueprism Solution Design Overview Guide pdf cannot loccate
12-04-21 01:47 AM
I am not able to search under Documentation / Guides.
I am planning to give Blue Prism Solution Design Architect Certification need some training.
So looking for this Guide but it is not available.
I also need Advance Work Queues / Solution Design Guide etc but cannot locate these.
Please help me.
Izaan Maredia
Please help me.
Izaan Maredia
12-04-21 12:22 PM
Hi Izaan,
You can access all of the guides you need in the Blue Prism University section on the portal.
You should be able to access Blue Prism University at the below link:
https://university.blueprism.com/pages/40/blue-prism-university
I hope this helps.
Kind Regards
Kieran Johnson
Finance Digital Worker Champion
United Kingdom
I hope this helps.
Kind Regards
Kieran Johnson
United Kingdom
25-03-22 12:37 PM
Hi Izaan,
I am also facing the same issue. Did you able to find out the study material. The link shared below is also not working.
Thanks!
Pallavi Vishnoi
Application Developer
IBM
Thanks!
Pallavi Vishnoi
IBM
25-03-22 02:01 PM
Hello @Pallavi_Vishnoi,
Yes, most of the guides that use to be readily available on the Blue Prism portal under Documentation are now embedded within some related training curriculum. So you have to find that training and enroll in it in order to get access to the support material (ex. PDFs). For Solution Design, I believe this is the training you want:
https://blue-prism.docebosaas.com/learn/course/276/play/35728/pdf-download-solution-design-overview-en
Simply enroll in the class and then you should be able to download the guide.
25-03-22 02:20 PM
plus
web link below if you want to go on course module by module( total 8 ) and test in the end
https://blue-prism.docebosaas.com/learn/course/19702/play/43171:783/solution-design-overview
Neeraj Kumar
Technical Architect
Neeraj Kumar
Technical Architect
