10-10-22 10:32 AM
Rana Abu Samhan
10-10-22 01:57 PM
Hi @Rana Abu Samhan,
Which Microsoft Office version you are using?
Try the below link if it helps:
https://stackoverflow.com/questions/6649363/microsoft-ace-oledb-12-0-provider-is-not-registered-on-the-local-machine
Manpreet Kaur
Manager
Deloitte
*If you find this post helpful mark it as Best Answer
10-10-22 10:37 AM
Saja Ismael
10-10-22 01:57 PM
Manpreet Kaur
Manager
Deloitte
10-10-22 01:58 PM
Also, the subject line states that you are facing issue with 'Java Mode'. Are you facing any issue with respect to spying java apps as well?
Manpreet Kaur
Manager
Deloitte
11-10-22 07:41 AM
Thanks a lot, your solution solved my problem.
Yes I have a problem in Java Mode, it didn't work "error spying"
Rana Abu Samhan
