Section 9 - work queues
AliNaser
I am doing the bp foundation course and I am stuck in section 9 (Work Queues).
In the second video - working item; once the action stage (Get Next Item) is added, then run the process; the data item and collection data would have values. Also when going to the control room, the video shows work queue and items to be processed. For some reason, I do not have any item, and it seems that no data provided in my queue! Can you help?
Ali Naser
Carl__Carter
Hi Ali,
As part of the setup of your local training environment, you are instructed to open and run the process named 'Load Queue'. Once you have run this process, items will be available in your Work Queue. You can run this process multiple times if required.
Information about setting up your training environment can be found in 'Section 1 - Introduction' of the Foundation Training course. You are looking for the guide named 'Foundation Training Setup'.
Hope this helps.
Carl Carter
Developer Program Manager
