Solution to Surface Automation Training
RonAng
Hi, Where can I get/see the solutions for the v5 Surface Automation - Training Course? This is so I can confirm if my solution is correct and in accordance with the course. Thanks!   Regards, rang1
We do not provide a solution to the Surface Automation training.  I would also ask that other Portal Users do not attach a solution to this thread as it will simply lead to other trainees using that rather than fully understanding. If you are taking BP training the expectation is that you will have a lead developer or consultant mentor available to you if you need help with anything within the training.  If you look at the Accreditation Training path - part of that training is mentoring.  If you have not been allocated a mentor to help you please raise that with your RPA manager as an issue.
