Hi I am trying to get pg 10 ('GetDetails' BO) of the Adv. Surface Automation module (Developer Cert) to work, where you set the System Generated Arial 9.5 font and capture your regions etc.
I believe I've followed the instruction as required, but when running my updated 'GetDetails' BO, the resulting Data Items seem to only be populated with '|' pipe chars instead of the respective field text.. Any ideas?  (image attached)
Patrick
