Work Q with mutiiple Resource PC
sidram.m
​Hi,
I have implementes Work Queues for bulk data process and used one resource pc. How this woks in a productions sysstem where more than one machice connected to same control room. How to map same process to multiple resouces?
Sidramappa Hunashyal
SA
Accenture
Carl__Carter
If you have not already done so, it would be worthwhile completing the Blue Prism Foundation training which is available through the Blue Prism University. Also, a read through the Advanced Work Queues guide will help.
Assuming you have available Blue Prism licenses, then a Process can be run on multiple Resource PCs simultaneously. It's just a case of starting the process on the relevant Resource PCs.
Carl Carter
Developer Program Manager
