data stored in process studio does not flow to objects
LeonaC
Hey Everyone,
I just start learning blue prism, and one thing I lean from watching the training videos is that data/values should not be stored in objects. Instead, they should be passed down to objects from process studio. However, my object studio has troubles getting data from process. I feel like there is a disconnection because if I leave the value in object the bot runs perfectly. I already modify the start stage in object to capture values from process and the issue is still there. Could anyone advise? Thanks in advance!
NrupalJoshi
Unfortunately, I cannot see the attachment. Can you increase the size of it? How are you passing values from process to object (or vice-e-versa)? Through end and start stages?
Rup Joshi
LeonaC
@NrupalJoshi
Thanks for helping! I have updated the post. Yes, I used the start stage in object (see attached) to let data flow from process object. however, it might be somehow incorrect cuz it is not working properly
