Blue Prism Product
 View Only
last person joined: 16 hours ago
This community covers the core Blue Prism RPA product.
  • 1.  Global send key and ALT (^) key stroke in Notepad
    Posted 8 days ago
    Hi
    I try to use the ALT key in notepad like {ALT}+f "@f" to open the file menu. It doesnt work it just write @f in Notepad, but if I do {CTRL}+s "^s" to save the file it promt me with the window to save the file.
    Can someone help me?
    I'm developping with Blue Prism 7.1
    Bernard Theroux
    Blue Prism Certified Developper
    Bell Canada
    Montréal, Qc, Canada
  • 2.  RE: Global send key and ALT (^) key stroke in Notepad
    Posted 8 days ago
    @Bernard Theroux
    I don't use send keys all that much but looking in the .Net Sendkeys documentation, it says that the "%" is used for the ALT key:
    Micheal Charron
    Senior Manager
    RBC
    America/Toronto
  • 3.  RE: Global send key and ALT (^) key stroke in Notepad
    Posted 7 days ago
    Hi Bernard Theroux,
    As mentioned for Shift(+), CTRL(^), Alt(%)
    AlT+F - Try using "%{F}" it will open the file menu
    Refer this Global send key documents for
    https://community.blueprism.com/viewdocument/global-send-keys-a-guide-to-send
    Harish M
    Lead developer
    America/New_York TX
Welcome to the Blue Prism RPA Product Community!
Whether you’re looking to manage a complex infrastructure, maintain security and compliance, bring new products to market faster, or gain operational speed and agility in an uncertain economy, Blue Prism delivers — with the flexibility you need to create the business you want. From deployment on-premise, through a cloud service provider or as SaaS, to a skillful and adaptable digital workforce that continually expands to meet your enterprise needs, you can gain enhanced operational insight and control while your people reclaim the time they need to focus on great work.
Product PageKnowledge BaseBlue Prism Training Offering
Product Research ProgramUpdates, Releases & Announcements
FAQs
Blue Prism is intelligent automation — business-developed, no-code automation that pushes the boundaries of robotic process automation (RPA) to deliver value across any business process in a connected enterprise.
A combination of RPA with expanded cognitive and AI capabilities, Blue Prism is different than other automation technology on the market. With one Blue Prism license, you gain instant access to an already AI equipped digital workforce, along with the tools you need to build and delegate automations. Click here for more information on Blue Prism and Intelligent Automation.
To learn more about how Blue Prism RPA can help your organization and how much it will cost to get started, please Contact our Sales department.
Blue Prism RPA can be downloaded from our customer portal. If you would like to consume or download any material it is necessary to create an account on the Portal. Once you have registered, you can access the download options for Blue Prism here.
Yes! Installed on your own machine and supported by our training materials and product documentation, you can use all the features of the full enterprise product for free with our Blue Prism Trial – giving you the opportunity to learn the basics before moving to a full production implementation. Click here for more information and to download the trial.
Yes! You can access our known issue list for Blue Prism from our Support Portal.
Regardless of your industry, Blue Prism’s Digital Workforce can adhere to strict governance and compliance standards without limiting productivity. Click here for more information on how your industry can benefit from Blue Prism.
