Not able to Spy Scroll bars
SenthamaraiA
I am working in an Web Application, Where there are two scroll downs are present in the web page. When i passed the key stroke as "{PGDN}" "{DOWN}" through global send keys only the outer scroll bar is moving down.
Need help to scroll down the inner scroll bar
Mukeshh_k
Hi @SenthamaraiA  - Do you have a sample snip of the web app or the manual behaviour of page when tested ? Try pressing Space Bar - if that works.
Mukesh Kumar
plnarayana777
Level 7
if the requirement is to scroll to some element present in inner section then you can spy the element and use navigate stage with option to scroll to (action)
if their is any other requirement then you can specify the requirement with screenshot
Lakshmi Narayana
