How do I edit my posts and comments?
The community allows you to make changes to any post you've created. This means that you can correct errors, update information or change the look and feel of your contributions to the community even after you have published them.
To edit one of your posts or comments, click the arrow in the top right and select "Edit Message":
You will then be taken to the Post Editor, where you can make changes to your post or comment. Once you're happy with the changes, just click "Post"!
I can't seem to edit my post...
Note that you can only edit your own posts and comments. If you're having trouble editing a post or comment, get in touch and we'll help you get it sorted out!
