data stored in process studio does not flow to objects
LeonaC
Hey Everyone,
I just start learning blue prism, and one thing I lean from watching the training videos is that data/values should not be stored in objects. Instead, they should be passed down to objects from process studio. However, my object studio has troubles getting data from process. I feel like there is a disconnection because if I leave the value in object the bot runs perfectly. I already modify the start stage in object to capture values from process and the issue is still there. Could anyone advise? Thanks in advance!
KaranSareen
The Start properties page you are showing is only for saving the values that are passed on from the Process into the local variables in the Object?
You need to pass the value in these parameters when you call this object from the Process. Could you please double check and confirm if you are passing these values from Process to the Object?
EVIPUTI
You are defining them wrongly , instead of process start up parameters they should be defined in action stage while calling that object ,
