As
@sravangoud implied, GraphQL is a bit more formal with regards to input than your average RESTful service. Here's an example of a simple public service I created a quick Web API service definition for as a test:
Note, the query portion of the body must be created essentially as a string with embedded newlines. You can test against this same public service and view it's schema here:
https://countries.trevorblades.com/Cheers,
