ATTEMPTING TO CLICK ON A PROMPT CREATED BY CODE STAGE
IngridBardales
Hi team hope all is well!! I generated a message box from the Code stage and I'm trying to click on it by trying to spy it with App Mod.  However, I can't access App Mod because the button is still active.  A solution to this is greatly appreciated! Thank you, Ingrid
You can't use the same object to click a button that the object has generated - it's a catch 22 because the dialog box is modal and blocks the execution of the object until the button is pressed.
