01-10-21 05:14 PM
04-10-21 01:07 PM
04-10-21 01:54 PM
06-10-21 05:17 PM
Yeah - that does not sound right. Sounds like the logic has been confused into thinking you are two users rather than one?!
I presume it works as expected if you do not do the '3. Set next stage back' step in the actions you took.   In that step you were in the object,  where did you set the next stage - did you set it back in the process or was it still in the object?  I could imagine that stepping into an object and then setting net stage back in the process would fool the product - I always set next stage on the end stage of the object action and then stepped out cleanly.
12-05-22 02:41 PM
