Add a note to a Process or Object directly in Studio
PvD_SE
Level 12
I would appreciate the possibility to add notes to a process or object directly in Studio. The reason for my request is that when you are maintaining a process or object, you might observe issues that you cannot address directly but would like to write down for the next development opportunity.
Possible solution:
You would right-Click on the process or object, chose option 'Add Note' and write your comment.
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
Hi Paul,
Thanks for post, it caught my eye and I wondered if you could explain what you would want to see in Studio in addition to what you could already get by adding a "Note" stage to the canvas? Is that you're wanting something more than just a free text pad to jot ideas down on?
Once you've received some contributions from other community members it would be great if you could summarise your thoughts in an idea on the Ideas Portal (Get Involved > Ideas) and then this can work it's way through our enhancement review process.
Rob
Robert Nicklin
Senior Product Owner
Warrington, England
Rob Nicklin
Associate Director of Product
Warrington, England
