Application modeller and spy is stuck when application provides big data tables
StefanJäger
Hi there, We do have an issue when identfying elements via the Application Modeller in case the application shows big data tables. It appears that Blue Prism is not reacting anymore and only stops it processing once we close down the application in which we want to automate. Is there any advise on how to deal with Application Modeller and different spy modes for applications which provide large data tables? Are there any known limitations in that regard which you can share with us? Please note we're using BP 6.2.1. Is it also possible that more recent versions fix issues in regards to performance? Please also note that this issue hasn't appeared in our previous version which has been BP 6.2.0. Looking forward to your feedback. Cheers, Stefan
Hi Stefan - if you've not already done so, please also raise a support ticket for technical advice.
