Hi M,
What your message shows confirms that the extension was not started and BP cannot connect with Edge. Activate the extension and try again, that should make all actions in the object modeller work.
If the problem persists: What problem do you get when you activate the extension?
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
