Attaching excel instance by excel vbo with macro
02-11-22 04:42 AM
I have an issue where i am trying to run macro on the workbook opened by excel but it instead is creating a new excel instance to run the macro on that.
Pooja Verma
Pooja Verma
02-11-22 07:16 AM
Hi Pooja,
Trying to understand what's going on: So your XL is already opened and your process has attached to it (by creating an instance) and when you access it the process creates a new instance?
The usual way to use an existing XL in a process is:
Happy coding!
Paul
Sweden
- create an instance (you'll get a handle back)
- open the XL with the handle and path
- work with the XL (get data, write data)
- save (or save as) the XL
- close the XL
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
Paul, Sweden
