Hi Pooja,
Trying to understand what's going on: So your XL is already opened and your process has attached to it (by creating an instance) and when you access it the process creates a new instance?
The usual way to use an existing XL in a process is:
- create an instance (you'll get a handle back)
- open the XL with the handle and path
- work with the XL (get data, write data)
- save (or save as) the XL
- close the XL
If you don't start by creating an instance, you do not have a handle and the process cannot open the XL.
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
