Attachmate InfoConnect not working with BP
ArkadiuszJakub2
I have a problem with Attachmate InfoConnect automation in BP.
After application modeller is correctly set up, the mainframe window shows up like on pic below:
kh_placeholder.pngIt`s impossible to extend/maximize it.
Did you encounter this kind of issue?
Thanks a lot in advance for any assistance!
mhagen
Hi Arkadiusz,
I have a question back. After setting up the application modeller correctly, are you able to start the application and highlight the different items manually within the application modeller? So that the incident appears when letting the process running automatically? Or does the error occur right from the beginning, so that you cannot highlight the different items on the Attachmate InfoConnect application manually?
Thanks, and wish you a nice day, Michael
