11-01-23 11:05 AM
11-01-23 12:17 PM
11-01-23 02:17 PM
11-01-23 02:58 PM
11-01-23 02:59 PM
12-01-23 01:55 PM
12-01-23 02:16 PM
13-01-23 11:37 AM
14-04-23 05:32 PM
Hi, Kirsty:
We're in the process of converting to Blue Prism from Kofax RPA at my work, so this might be my inexperience at play here, but we're seeing a similar error.
Most of the time (but not every time) I try to launch the Microsoft Edge browser, I receive the following error: "Internal : Failed to perform step 1 in Navigate Stage 'Open Browser' on page 'Open Browser' - The query did not match the window title provided, please try again." The strange thing about it is that the browser window always opens, regardless of whether the error message pops up.
Because this is a root-level application spied by Application Modeler, I don't have the ability to modify it nearly to the level I can for a child.
Any suggestions? I really appreciate any help that anyone can provide here.
-John
14-04-23 06:27 PM
Hi @John Schreier  is it launch action that is failing or the attach action ? and if its launch action are you killing the browser before each retry ? - I would usually leverage Utility Environment - Start process action to launch, wait 5 seconds and attach it via Business Object
If Launch fails from this block I would kill edge by Taskkill and retry it:
If its attach which is failing - Keep the windows title as wildcard * : something like this and check if its highlighting the outer window- if the window titles are changing and if at least some part of window title is common in each window better to use that as wildcard  :
