Hi Shweta,
There's currently no standard way to get that information. Though I would guess the different field names may help indicate the document type.
Alternatively, you can create a new field in the DFD, uncheck the "assignable" flag, check the "hidden" flag and set the default value as the document type name. This will create a new fields to be exported with every document, but users will not see it (hidden) and Decipher will not try to assign it to a region.
Or if you have the access and skills required, it would be possible using SQL commands. But we do not generally recommend using SQL where the database performance could be impacted.
Ben
Ben Lyons
UK based
	Ben Lyons
SS&C Blue Prism
UK based
