26-04-23 09:02 AM
Migrating from Blue Prism Decipher 1.2 to 2.2 may present some challenges and potential problems, including:
Compatibility issues: Blue Prism Decipher 2.2 may have some changes to its architecture, and this can cause compatibility issues with the existing code in version 1.2. As a result, migration may require modifying the existing code to ensure compatibility.
Learning curve: Blue Prism Decipher 2.2 may have new features and functionalities that were not available in version 1.2. This may require additional training for developers and users to learn how to use the new features effectively.
Deployment issues: Migration can be complicated and may require changes to the deployment process, especially if the deployment is automated. Changes in the deployment process can cause delays and impact the productivity of the team.
Testing and validation: After migration, testing and validation of the migrated code is essential to ensure that everything is working correctly. The testing process can take some time and may require additional resources.
Security issues: Blue Prism Decipher 2.2 may have new security features or changes to the existing security framework. This can cause security issues when migrating from version 1.2 to 2.2. It is essential to address these issues during migration to avoid potential security breaches.
Third-party integrations: Third-party integrations with Blue Prism Decipher 1.2 may not work with version 2.2. This may require changes to the existing integration or redeveloping the integration from scratch.
Downtime: Migration may cause downtime, impacting the productivity of the team and the business. It is essential to plan for downtime and ensure that the necessary resources are available during this period.
Overall, the migration process from Blue Prism Decipher 1.2 to 2.2 requires careful planning, testing, and validation to ensure a smooth transition and minimize potential problems.
Jagadish Patro
27-04-23 02:46 PM
Hello Jagadish,
Here is the link to known issues for Decipher 2.2 - URL
Here is the link to the FAQ section - URL
Attaching an official guide for Decipher 2.2 installation and upgrade procedure where precautionary steps are mentioned before upgrading.
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
26-04-23 03:24 PM
Hi Jagadish.
You bring up good points that one should consider for pretty much any upgrade. However, I can tell you that the actual product upgrade is quite straightforward and easy.
There are no destructive changes to the database so all of your training data, DFDs, etc convert easily. Testing and planning are a given, but I have not seen any great difficulties in the migration between the two versions.
jack
Jack Look
Sr Product Consultant
27-04-23 04:40 AM
Hello Jack,
1) Is there any known issues in version 2,2 .
2) what other challenges will come during migrate from version 1,2 to 2,2
3) How much time will take to migrate from decipher version 1,2 to 2,2
Jagadish Patro
27-04-23 02:46 PM
Hello Jagadish,
Thanks & Regards,
Tejaskumar Darji
27-04-23 02:59 PM
Thank Teja for the excellent response to Jagadish's question.
Jack Look
