25-02-21 07:26 AM
Blue Prism issue with Attaching applications
I am facing a major issue with BP Attaching to applications. The process would work fine for a long time, then all of a sudden, BP can't attach to an application, and the only way to recover is to log off the server, and log back in and restart the process. It would work after that but after few hours, the issue will again persist.
Is the issue related to the Server itself running something in the background? And what is the solution that can work? Any suggestions will be appreciated.
14-10-21 07:05 PM
25-02-21 10:26 AM
25-02-21 03:43 PM
26-02-21 03:30 AM
26-02-21 03:40 AM
Thank you Chris for your solution.
Apparently, we are using separate VBOs for the process that includes the Attach functionality. The main issue here is that the process seems to be able to complete 20 plus cases from control room but then suddenly at 21st case, it throws the Attach issue. But after restarting the process it again works fine for many cases and then again it throws the same Attach issue. I wish to know the root cause of the issue. It doesn't seem to have the exact issue with Attach here since it works fine for multiple cases. And it seems to be able to detach and attach to the application fine for most of the cases.14-10-21 05:15 PM
14-10-21 07:05 PM
3 weeks ago
unfortunately, that link does not work for me
