17-06-21 07:15 PM
we are making below 3 steps to SFDC :
All the above operations are performed successfully in dev and UAT. But in production, some times the above steps are successful and some times they are failing. Below message is appearing in production intermittently when ever bot fails to connect SFDC API/get/post:
Could not execute code stage because exception thrown by code stage: Object reference not set to an instance of an object
After looking into the logs, there is no issue at the SFDC . We cannot say that this may be a access issue as the process is successful sometimes and failing sometimes. We already had discussions with security teams. There is no issue at the Security perspective.
Please help us in resolving this issue. Kindly connect us to a related person who could solve the issue.
Bhavana Kalva,
23-06-21 08:57 PM
