Hi surajmadhale
Can you not use a navigate stage in business object, where you take the URL as path, instead of clicking into search bar, to go to an URL?
Not sure what you mean by: ""Comes after we choose base directory of spied object in Navigation stage (Please see attachment)"" ?
If you absolutely have to press into the search bar of IE browser, then
1) Spy IE search bar and have a navigate stage where you ""Click Window Centre"" action on IE search bar, not taking input on ""Mouse Button"".
2) Use a Writer stage where you input URL path into formerly spied IE search bar.
3) Use a navigate stage, where you send a ""Global Send Key Event"", with input to ""Text"" = ""{RETURN}"".
4) Wait stage to ensure you are at the path, you are supposed to go to.
Put recovery/resume and/or wait stages with actions in between the 4 stages, to ensure stability.
Good luck.
BR,
Mustafa
