BluePrismMAPIEx
04-05-18 11:28 AM
While sending consequent mails in blue prism some mails are missing. Example: if i am sending 4 mails (A,B,C,D) continuously only 3 mails like (A C D ) or (A B C) are sent. remaining one mail is missing. is there any alternative way to sent mails without missing of mails
04-05-18 10:35 PM
Yes, you can use the ""Email - POP3/SMTP"". It works 100% of the time for me.
07-05-18 06:21 PM
You may try also to add some fixed wait always after an email has been sent with Mapiex. What is the appropriate wait time in your system can be found by testing different times.
