#BpTechTips - How to Move Folders Easily using Blue Prism
22-11-24 02:17 PM
Hello everyone,
Did you know you can easily move an entire folder from one path to another using the ATCS - File Management VBO?
This action lets you perform folder operations efficiently, saving you the hassle of moving files one by one from one folder to another and then deleting the original folder!
List of all actions available,
This VBO can be used for additional actions that are not part of the native File Management VBO
22-11-24 06:51 PM
Thanks for the tips 🙂
Do you have any action that allow us to rename the Folder ?
Actually we use the cmd command "move" to do it
23-11-24 08:33 AM
Yes, to rename the folder also you can use this asset ATCS- Rename File and Folder
This will reduce move effort and directly rename the folder in a single step.
