Built in APIs
IbrahimDemolli
Hi all,
I'm very interested in knowing if is there any provided API-s by BluePrism, for example, Starting or stopping any process or whatever?
Ibrahim Demolli
Elba Technologies
AmiBarrett
Level 12
You can make use of AutomateC.exe, located within the Blue Prism directory. Call it via command line to get a list of commands.
"C:\Program Files\Blue Prism Limited\Blue Prism Automate\AutomateC.exe" /?​
Ami Barrett
Sr Product Consultant
Richardson, TX
JerinJose
Level 10
​You can also expose a process/object as webservice and execute it on runtime resources. exposed process will be available as a SOAP webservice.
Jerin Jose
RPA Product SME
EY
Simon_AndrePede
Hi Ibrahim,
This is definitely possible. Blue Prism provide a commandline interface to control Blue Prism using its Robots (Like mentioned by Ami).
This commandline interface is also available through HTTP, which, I personally prefer compared to the more local commandline interface.
You can see all the commands available in the Help section of BP or you can also checkout this article:
http://portal.blueprism.com/customer-support/support-center#/path/1421412402
http://portal.blueprism.com/customer-support/support-center#/path/1232324412
Jerin also point out you can expose every object and process as webservices. For this you need to consider best practices in term of license usage. But it is a very powerful feature as well.
At my projects we heavily use all above, and it is extremely powerful and fun to work with.
Simon Andre Pedersen
Senior Associate
PWC
Asia/Hong_Kong
