CST----(Machine name) is too busy to run the process
what are the scenarios when we get the error "CST(Machine name) is too busy to run this process" when we drag and drop any process to a particular machine in control room?
That message indicates the machine is already running a process or has a session pending. Note that he default view in Control Room is 'today' and a pending session created earlier will not be visible at first. BP can run multiple processes on the same machine but only if the 'Run Mode' of the objects used by the processes are in agreement. Run Mode is set on the Initialise page of every object and can be set as Exclusive, Foreground or Background, and only certain combinations of these enable parallel processing. For example, if a process uses and Exclusive object, no other process can run on the same machine at the same time. Two processes using only Background objects can run in parallel.
