Calculate and Formula language
22-09-20 11:10 AM
I want to check whether 2 fields have same value or not. How can I achieve this.
So far I tried like - FT_FIELD1=FT_FIELD2, #FT_FIELD1=#FT_FIELD2, @FT_FIELD1=@FT_FIELD2, EQ(FT_FIELD2).
But none of them showed any validation error if the values are not same. Can you help.
Thanks.
Tejaskumar Darji
Thanks.
Tejaskumar Darji
22-09-20 10:03 PM
Have you assigned the calculable flag in the field options?
In your example, you are trying to validate the value of field 1 based on the value of field 2? Then, try putting FT_FIELD2 in the formula for FT_FIELD1. Or self-reference: SELF = FT_FIELD2.
For an auto-calculated field, EQ(FT_FIELD1, FT_FIELD2) should return a true/false.
For text, some string functions to consider: STRCMP(FT_FIELD1, FT_FIELD2) for case sensitive, or STRICMP(FT_FIELD1, FT_FIELD2) for case insensitive.
Patrick Aucoin
Senior Product Consultant
Patrick Aucoin
