Cannot add System.Core.dll reference
PanupongMakvic1
Hi everyone,
I face with this issue which is very odd to me. Now I'm using Blue Prism 6.3
I want to use LINQ so basically I need add System.Core.dll as an assembly. It worked fine with the first Blue Prism Object that I implemented.
Later, I create a new object which refer exactly the same external reference as the one before and I found this error
Description: Compiler warning at top section line -6: The predefined type 'System.Runtime.CompilerServices.ExtensionAttribute' is defined in multiple assemblies in the global alias; using definition from 'c:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorlib.dll'
this issue seems like it already refer to mscorlib.dll which already contains system.core as a namespace
what is strange is that why my first object is still working fine but this new object has error even all the same references.
Pls suggest me.Thank you guys
Panupong Makvichian
PanupongMakvic1
Attached pictures
Panupong Makvichian
