Checkbox not clicked
RaviKumar3
Hi,   Can anyone help me out to handle checkbox. I have spied using HTML mode and there is no issue in identifying the element. But sometime its clicking on checkbox and sometime not.
There are many different ways to interact with Checkbox elements in browsers using HTML/Browser mode, using Accessibility Mode (or UIA mode if you are using 6.2 or later) and using Surface Automation. For many of the interfaces you can send a click or press event, a global click event (make sure you activate the window first and have a tiny wait - as in the Surface Automation training on using global clicks or global send keys), you can use a write stage that sends ""True"" or ""False"", etc. What options have you tried?
RaviKumar3
Thanks Dennis   Its working now. I have put condition on if checked or not and also put retry if its unchecked.I have put the conditions what you mentioned and its working fine after 1 or 2 trials.
