07-11-24 12:42 PM
Hi Everyone,
Please assist me in getting the VB code for Blue Prism to clear duplicate values from an Excel sheet.
For reference, kindly refer to the attached image.
10-11-24 08:55 AM - edited 10-11-24 09:00 AM
Hi @BENDRES
Follow these steps :
Go to MS EXCEL VBO and add a new action, name it 'Apply Remove Duplicate [CUSTOM]'. Then drag and drop a code stage like this :
Now open the code stage and provide these inputs :
Do the same for output :
in code stage put this :
Like this :
Now, Your action should look like this :
Publish your action, save and go to process now.
Your process should look like this :
Lets do the test now.
I have this excel file see below :
I want to make the remove duplicate on my column A so its my first column.
I want also to start at cell 2 and finish at cell 8
so i give these parameters in my new action see below :
now run your flow and you will have this :
Try it and let me know. If it works for you, please mark me as best answer.
10-11-24 06:53 PM
By the way you can use the latest version of MS EXCEL VBO in DX : https://digitalexchange.blueprism.com/dx/entry/3439/solution/ms-excel-vbo
you can find this action :
Try it and let us know if it work for you mark me as best answer
07-11-24 07:42 PM - edited 07-11-24 07:43 PM
Hi @BENDRES
What i can suggest you its to get your excel file as a collection then you make the remove duplicate and then you save your excel file.
It will be easier.
Is it ok for you ? or its mendatory to have a custom code stage ?
08-11-24 07:22 AM - edited 08-11-24 07:26 AM
Hi @Mohamad_747
I appreciate your suggestion.
Since I have a lot of data in 25 columns, I don't want to take it into collection because it could become stuck or there might be a format change.
It will work better with coustom code because just need clear the cell value.
Hi @BENDRES
Like this :
10-11-24 02:28 PM - edited 10-11-24 02:35 PM
Hi @Mohamad_747,
I wanted to extend my sincere thanks for sharing the Blue Prism VB code to clear duplicate values from an Excel sheet. I tested it & it worked perfectly, meeting my requirement as expected.
Can we add sorting of sheet with Column "A" before clearing the duplicate cell.
Your support and guidance have been invaluable & this solution will greatly enhance my automation process.
Thanks once again for your help!
Best regards
10-11-24 04:46 PM - edited 10-11-24 04:48 PM
Hi @BENDRES
Sorting on which criteria ascending or descending ?
What if we have blank value ?
Please mark me as best answer.
10-11-24 06:53 PM
11-11-24 05:27 AM
Hi @Mohamad_747 ,
It meets my requirements and performs as expected.
Again, thank you for your assistance!
Best regards
