Clear Duplicate Values from Excel sheet VB code stage
BENDRES
Hi Everyone,
Please assist me in getting the VB code for Blue Prism to clear duplicate values from an Excel sheet.
2 BEST ANSWERS
Hi @BENDRES
Follow these steps :
Go to MS EXCEL VBO and add a new action, name it 'Apply Remove Duplicate [CUSTOM]'. Then drag and drop a code stage like this :
Now open the code stage and provide these inputs :
Do the same for output :
in code stage put this :
Dim ws as Object
Dim previousVAL As String
Dim currentVAL As String
ws = GetWorksheet(handle, workbookname, worksheetname)
Try
previousVAL = ""
For i = start_row To last_row
currentVAL = ws.Cells(i, remove_duplicate_column).Value
        If currentVAL = previousVAL Then
            ws.Cells(i, remove_duplicate_column).Value = ""
        Else
            previousVAL = currentVAL
        End If
Next i
Catch ex As Exception
exceptionMessage = ex.Message
End Try
Like this :
Now, Your action should look like this :
Publish your action, save and go to process now.
Your process should look like this :
Lets do the test now.
I have this excel file see below :
I want to make the remove duplicate on my column A so its my first column.
I want also to start at cell 2 and finish at cell 8
so i give these parameters in my new action see below :
now run your flow and you will have this :
Try it and let me know. If it works for you, please mark me as best answer.
@BENDRES
By the way you can use the latest version of MS EXCEL VBO in DX : https://digitalexchange.blueprism.com/dx/entry/3439/solution/ms-excel-vbo
you can find this action :
Try it and let us know if it work for you mark me as best answer
7 REPLIES 7
Hi @BENDRES
What i can suggest you its to get your excel file as a collection then you make the remove duplicate and then you save your excel file.
It will be easier.
Is it ok for you ? or its mendatory to have a custom code stage ?
Hi @Mohamad_Dakkouri
I appreciate your suggestion.
Since I have a lot of data in 25 columns, I don't want to take it into collection because it could become stuck or there might be a format change.
It will work better with coustom code because just need clear the cell value.
Hi @BENDRES
Dim ws as Object
Try
previousVAL = ""
        Else
        End If
Next i
End Try
Like this :
Hi @Mohamad_Dakkouri,
I wanted to extend my sincere thanks for sharing the Blue Prism VB code to clear duplicate values from an Excel sheet. I tested it & it worked perfectly, meeting my requirement as expected.
Can we add sorting of sheet with Column "A" before clearing the duplicate cell.
Your support and guidance have been invaluable & this solution will greatly enhance my automation process.
Thanks once again for your help!
Best regards
Hi @BENDRES
Sorting on which criteria ascending or descending ?
What if we have blank value ?
Please mark me as best answer.
@BENDRES
BENDRES
Hi @Mohamad_Dakkouri ,
It meets my requirements and performs as expected.
Again, thank you for your assistance!
Best regards
