Hi All,
Has anybody experienced this behaviour? I am trying to decide if this is by design, an overlook in design, or a bug in the application modeller. When using Region Mode, if you create a region stored by Image, Click Center and Global Mouse Click do not work correctly. If you create it by Region, they work fine.
My current workaround is to find the image region first, and then find a coordinate region which is related to the image region, of the same size and padding. Then, I perform my click actions on the Coordinates.
