If it is too complex, you can write/debug code in visual studio, but so far I managed to blindly code most of it, only sometimes passing some debug values outside.
Thanks aikudino! This is what I've been doing as well. It does become a bit burdensome to get it into Visual studio because of the global code/libraries. Certainly simple enough but feels like a time-waster.
The code stage was always intended as an execution mechanism rather than an IDE. But I agree, debugging is a pain in the #### and for anything more than a handful of lines it's easier to perfect the code in something like VS and then copy across.
I write all the complex code in Visual Studio and then copy it into code stage.
If it a simple datatable manipulation, loops, regex, string manipulation etc I directly use the code stage. It’s not that difficult.
