Consume Web Service Soap with header authentication
deise.santos
I'm trying to consume a SOAP web service with a basic authentication scheme. As per the guidelines in the Blue Prism Web Service guide, I generated the code using "wsdl.exe" and included it in the object's initialise. I created a new action and included in a code stage the C # code to authenticate and invoke the web service method I need. But Blue Prism is experiencing the following error "The request was canceled: A secure channel for SSL / TLS could not be created." I tested the same code used in Blue Prism in Visual Studio and it worked correctly. Does anyone have any suggestions to solve this problem?
Analista de Negócio
CSC Algar
deise.santos
The problem was solved by adding the code below:
ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls
| SecurityProtocolType.Tls11
| SecurityProtocolType.Tls12
| SecurityProtocolType.Ssl3;
Analista de Negócio
CSC Algar
