Control Room Terminated
01-11-19 01:47 PM
Dear community !
How are you doing?
I'm facing a issue, someone can help me?
When I drag and drop my process from my Dev envirounment to my Prod. envirounment to execute the bot automatically, I select the session and start. The session status change to running, but as soon change to status Terminated and stops.
I checked the queue already , I tried to delete the packets, but its is impossible, I get the following message:
Database error - Could not allocate space for object 'dbo.BPAWorkQueueItem'.'Index_BPAWorkQueueItem_queueident_finished' in database 'RPA' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Please check the attachement.
Someone can help?
Sincerely
Jeferson Romão
Developer
Lyo Solutions
How are you doing?
Someone can help?
Sincerely
Jeferson Romão
Developer
Lyo Solutions
14-11-19 01:32 AM
Hello Jeferson
It looks you need to do the database maintenance at this point. You can get in touch with the Blue Prism Support team and they can provide you with the House Keeping scripts which you can then use to free up some space on these tables. Blue Prism will start working normally after that.
Karan Sareen
Solution Support Engineer
Blueprism
Australia/Sydney
Karan Sareen
Blueprism
Australia/Sydney
