Hi Dilip
How is the shared folder stored in your bot is it for example T:\my folder\my files\
Does your bot access the folder fine if your run it manually but cant access if its run through the scheduler?
If so then change your folder address to look like this \\my folder\my files\ and try running it from the scheduler again and this should hopefully resolve the issue. If not then check the level of access hasnt changed to the folder your are trying to access.
Hope this helps
Michael ONeil
Technical Lead developer
Everis Consultancy
#MVP
