Could not initialise Java Access Bridge support - Failed to load Java Access Bridge DLL
JB4128
We have a Blue Prism automation that runs daily, usually with no exceptions that uploades files to a website.  However it gets an intermitant error:
"ERROR: Internal : Failed to perform step 1 in Navigate Stage 'Attach' on page 'Attach' - Could not initialise Java Access Bridge support - Failed to load Java Access Bridge DLL. The file could not be found in any of the following expected locations -
Application Directory: C:\Program Files\Blue Prism Limited\Blue Prism Automate\WindowsAccessBridge-32.dll
System Directory: C:\WINDOWS\SysWOW64\WindowsAccessBridge-32.dll
Windows Directory: C:\WINDOWS\WindowsAccessBridge-32.dll
Current Directory: C:\WINDOWS\system32\WindowsAccessBridge-32.dll"
For some reason the WindowsAccessBridge-32.dll file goes missing.  We are able to fix the problem by copying the WindowsAccessBridge-32.dll into the c:\windows\syswow64\ folder of the run time resources whoever the problem keeps reoccuring every month or so.  Has anyone had this problem and fixed it so it doesn't keep happening?
Jodi Bates
10 REPLIES 10
Hi Walter,
We are facing the same issue now.Do you have fix for this?
